Hi everyone, I've got a cab chassis:
VIN number:
WF0CXXGBFC3J06450
Engine:2.4L Duratorq DI (120/125PS)
Power: 125PS
Wheels: RWD
Year: 2004
Transmission: 5-Speed Manual Transmission - MT75
Steering: RHD.
I bought it nearly a year ago, motor ran really well, but gear box was hard to move between 3 and 4th. Got a mechanic to remove gearbox and sent away to get fixed(took nearly 3 months). Gearbox came back and was refitted, along with a new clutch. Went to start up, but wouldn't- just revved for a second or 2 then abruptly cut off, every time. Got him to check the wiring (tried to get a reading from the computer but it wasn't talking to his machine), since then it will turn over normally but won't start. I tried swapping crank sensor and speed sensor harness - still no go. Just bought and fitted new crank sensor, but still not working. Checked fuses, all look OK. Fuel is getting to injectors (cracked them open a bit and plenty of fuel was squirting out when trying to start).
Seems strange that it started and ran great before the new clutch and reconditioned gearbox was done.
Any other ideas? Thanks.
