Bluetooth scanner
Bluetooth scanner
Postby longhair » Mon Oct 30, 2023 1:57 pm
Hi
Looking for any recommendations for a Bluetooth obd scanner to measure soot levels in the dpf whilst driving. I'm after one because it seems that it quite often starts doing a regen after a good motorway run just as I'm nearly home or sometimes just as I'm pulling onto my drive. So my thinking was if I could monitor the soot levels building up, I would know when a regen was due and drive a different way back.
longhair
Re: Bluetooth scanner
Postby knobby1 » Tue Oct 31, 2023 2:33 am
longhair wrote:Hi
Forscan is out go to...on a laptop. not bluetooth or WiFi as they don't have the same functionality.
Postby Jaythesprayer » Tue Oct 31, 2023 10:32 am
Forscan now do a Bluetooth version for android and apple via the app
It’s called Forscan Lite
https://apps.apple.com/gb/app/forscan-l ... d892347083
Jaythesprayer
Postby longhair » Tue Oct 31, 2023 5:07 pm
I know Foscan with a laptop is better, but what I am after is a scanner that can be used during a journey so I can keep a check on soot levels. I'll check out the forscan lite, I just need to find a decent Bluetooth obd scanner.
longhair
Postby sherwoodcycles » Sun Nov 12, 2023 3:51 pm
Don't bother with the forscan lite on mobile. After buying a wired module (and giving up trying to get it to work) I thought I'd try the forscan lite. Wished I'd not wasted 7 pounds as my basic Bluetooth one was just as good.
One day I'll make the wired one work but it's very frustrating trying.
Greeny
sherwoodcycles
Postby longhair » Sun Nov 12, 2023 4:17 pm
sherwoodcycles wrote:Don't bother with the forscan lite on mobile. After buying a wired module (and giving up trying to get it to work) I thought I'd try the forscan lite. Wished I'd not wasted 7 pounds as my basic Bluetooth one was just as good.
Cheers for that, I think I'm going to go for the Vgate icar pro scanner and see how it goes.
longhair
Postby MinorMatt » Mon Nov 13, 2023 12:49 pm
Forscan lite on my mobile has been great. Its done pump and pilot learns, it gives likely causes of faults etc. It does have its limitations over the laptop versions - but it can do everything Torque Pro (just as an example) can and much more.
Postby sherwoodcycles » Mon Dec 11, 2023 9:27 pm
I found I couldn't get many things to work with the Bluetooth dongle and bought a laptop with Windows 10 . Back to the wired version and it actually works.
The common £12 carpro dongle will let u connect. I'm not sure if it will let you monitor as you are moving though.
Greeny
sherwoodcycles
Postby sherwoodcycles » Mon Dec 11, 2023 9:34 pm
Greeny
sherwoodcycles
