metalworker0 wrote:laminate flooring insulation
dumper wrote:What I’ve done with the camper vans I’ve built is waxoil the panels then use the plastic bottle recycled loft insulation then on the boarding out I’ve stuck carpet on and rolled the carpet over all the edges, glued and stapled them at the back about 25 mil overlap and then screwed them onto the van steel work this way if you need to remove them it’s very easy my last van I’ve used the proper carpet but on earlier vans I used the cheap thin foam backed carpet.This came in handy as on the previous van I had changed the side marker lights for l e d,s and one needed replacing so the board had to come off this was 10 years after I built it and the steel panels had no sign of rust. and the insulation was as in good condition as when I first put it in.
snowjoe wrote:metalworker0 wrote:laminate flooring insulation
Thanks Mark, that's a new idea on me! Is this the sort of thing you mean?https://www.ebay.co.uk/itm/175280289770
It says it does a bit of both (sound and heat insulation). If so, that could be a decent option!
dumper wrote:I googled plastic bottle recycled insulation and it says it melts rather then burns and is class e fire retardant.
