HVAC 2023 model
HVAC 2023 model
Postby boiledowl » Wed Dec 06, 2023 10:49 pm
The heating and air on this thing seems so hard to regulate. It is always too hot or too cold. It seems like the thermostat is way off. For instance it may be chilly in the cab so I put the heat on to about 68 then it just gets hotter and hotter. If I turn it down a degree it seems to get too cold.I am patient to let it settle out but it isn't very accurate unless there is a secret to operating it. Any ideas?
boiledowl
Re: HVAC 2023 model
Postby Frag » Sat Dec 09, 2023 3:50 pm
You’ve told us what model year,
but not what vehicle you are referring to…
Frag
Ford Technician
Re: HVAC 2023 model
Postby boiledowl » Thu Dec 04, 2025 2:20 pm
3.5 eco boost
boiledowl
Re: HVAC 2023 model
Postby metalworker0 » Thu Dec 04, 2025 2:55 pm
That's a V6 USA gasoline engine van ..no knowledge here, try the USA forums .
but suspect the "blend door actuator" fault
LOL - cant believe you took two years to answer Frag
Re: HVAC 2023 model
Postby Altransit » Fri Dec 05, 2025 10:53 am
