Fitting a towbar with a bypass relay
Postby Dorsettransit » Wed Dec 13, 2023 2:37 pm
Hi
Could anybody please help me out
I have a 2016 2.2 RWD that I have fitted a towbar to.
I have a bypass relay
But cannot find which colour wires I need to connect it to
Thanks in advance
Dorsettransit
Re: Fitting a towbar with a bypass relay
Postby loot » Fri Dec 15, 2023 1:55 pm
Is it a ford 1 or standard?
Ids map here
loot
Postby Dorsettransit » Fri Dec 15, 2023 7:07 pm
Just a standard one made by PCT Leisure
Dorsettransit
Postby loot » Sat Dec 16, 2023 12:30 am
It should be a 7 way bypass relay. The diagrams on the mk7 don't match the colour codes (no idea if it is the same on the mk8). But you'll easily be able to decipher the lamps that you need on the rear light cluster. Ground will be the continuous metal around all of the bulb holder and then the middle pin will go to the connector for each light function then the wire from that. And you can cut into the loom a bit away from that. You'll need to feed 1 wire over the back roof from the passenger indicator unless you can trace it. But by all means you'll need a mk8 diagram. I do have custom diagrams, I fitted a factory relay to my custom which was plug straight in and turn on with computer.
Ids map here
loot
Postby Paxophil » Mon Jan 12, 2026 10:37 am
Hi all. Im just about to fit one to my mk8 2017 custom. Can I use (if its there) the hidden 12v supply in rear to power the 7way bypass relay?
Paxophil
