Whiring noise, blue smoke
Postby Andymac365 » Wed Dec 13, 2023 11:46 pm
Hi guys, hope someone has had same problems. 2016 LWB 2.2 175k
Started a few months back, hard to start when hot, rough idle, low power, which pointed towards a egr problem, my mechanic has had it hooked up and everything is running as should, now am using oil and have blue smoke when pulling away and a whiring sound, thought it was a turbo pipe but there fine, it sounds like the turbo (no codes at all) spinning as I accelerate, which can get quite loud, not loud enough to scare sheep but I can hear it no problem in the cab, really struggles on inclines and smokes quite a bit. Some one pulled out on me yesterday and I did hesitate to brake hahaha
Andymac365
Re: Whiring noise, blue smoke
Postby Airthies » Thu Dec 14, 2023 12:10 am
Sounds like a boost leak or an intake restriction
Get a smoke test to determine if it's a boost leak.
Visual inspection of intake
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby andz327 » Sun Dec 17, 2023 11:20 am
Check the turbo impeller for exceswear/movement
andz327
