Exhaust Flange Gasket
Postby tbooth207 » Tue Dec 19, 2023 4:12 pm
2012 Transit Connect I have a leak in the exhaust flange just below the header pipe. I have been trying for days not to get the left site bolt out with zero success. You can get a socket on it but there is not enough clearance to get the rachet on the socket. I can get a wrench on it but cannot get any leverage on it to get the bolt started. I just put heat on the bolt and nothing is working. I'm not sure if there is a Ford specialty tool to get the SOB out or not. Any suggestions would be great, thanks.
tbooth207
Re: Exhaust Flange Gasket
Postby metalworker0 » Tue Dec 19, 2023 6:47 pm
1. pile of extensions on the ratchet .
2 3/8ths instead of 1/2 inch drive,
3 wobbly universal swivel on the extension.
4 support engine , undo mounts let engine move or tilt for more access
5. or if you can still drive it take it to a tyre and exhaust place .they are usually cheap.
Postby tbooth207 » Wed Dec 20, 2023 7:51 pm
I have tried all the 3/8ths options and its a no go. Next call is to a buddy that work for Ford to see if that calls for a specialty wrench then an exhaust shop after that.
tbooth207
Postby metalworker0 » Wed Dec 20, 2023 8:11 pm
forgot about this
may be useful
https://www.youtube.com/watch?v=WNoh9l2_74g&t=519s
Postby MinorMatt » Thu Dec 21, 2023 2:11 pm
Clearance spanner, or use a longer one/a spanner extender
