Mk7 Abs and esp lights on after MOT
Postby Doubledave » Wed Dec 20, 2023 6:27 pm
Hi
New on here, I’ve got a mk7 2010, much loved and well looked after.
Story goes..
In for MOT, no real problems need a track Rod ,( done and serviced privately by mechanic)
Pick it up, get couple of hundred yards, lights come on.
Go back, guy plugs it In removes codes.. off I go again,
Same happens, back again, Guy is stumped .
Steering wheel not completely straight, so after looking on your forum, said to guy, he straightened steering, still the same??
Garage waiting for an auto leccy to come out, but not till after Christmas.
So I’ve got van back for now, and hopefully someone on here’s got some ideas??
Thanks..
Doubledave
Re: Mk7 Abs and esp lights on after MOT
Postby knobby1 » Wed Dec 20, 2023 7:40 pm
Doubledave wrote:Hi
Story goes..
Thanks..
Not had new tyres by any chance..?? All ABS sensors ok..??
Was the SAS recalibrated once the steering was played with..?? If the steering wheel is not straight ahead, the system "thinks" the vehicle is going around a corner and then the wheel speeds don't make sense to it when you're going in th straight line...hence the ABS & ESP lights.
Postby Doubledave » Wed Dec 20, 2023 7:53 pm
Hi
Cheers for reply, not sure about the sas? Not sure if they did, but I doubt it.
Is it done electronically via the obd port ?
No tyres have been on a while and it was fine before MOT ?
Doubledave
Postby knobby1 » Wed Dec 20, 2023 11:18 pm
Doubledave wrote:Hi
You'll need Forscan or IDS to recalibrate the SAS. Make sure the steering wheel points straight ahead when driving straigh before you do it though....otherwise it will still have the fault light on.
Postby Doubledave » Thu Dec 21, 2023 10:38 am
Cheers, I take it that garages have those and know how to do this ?
Doubledave
Postby Frag » Thu Dec 21, 2023 11:35 am
You could do with posting the fault codes present while light is on.
More likely the ABS wiring has been disturbed or damaged during the T.R.E. Repair.
The light will come on if steering wheel is not straight while driving,
But usually only at higher road speed.
And if the wheels been set back to where it was it shouldn’t need SAS calibrating
Was the steering wheel straight before the T..R.E was replaced ?
Frag
Ford Technician
Postby Doubledave » Thu Dec 21, 2023 12:00 pm
Hi
Yeah wheel was straight before mot and no lights on.
After he straightened the wheel they had the diagnostic on it , would that recalibrate the sas?
Cheers
Doubledave
Postby knobby1 » Thu Dec 21, 2023 9:10 pm
Doubledave wrote:Hi
Cheers
Would only recalibrate it if the calibration program has been "enabled". It won't do it if you don't tell it to.
Postby Frag » Thu Dec 21, 2023 9:13 pm
It would if they ran the appropriate function,
And if their diagnostic machine had that function…..
But with no clue what the fault codes are,we don’t know if that’s the actual fault anyway…….
Frag
Ford Technician
Postby Doubledave » Thu Dec 21, 2023 9:52 pm
Ok cheers I’ve got it booked in another place for steering recalibration.
Doubledave
Postby Doubledave » Fri Dec 22, 2023 6:12 pm
UPDATE
Front wheel abs sensor faulty, got it booked in the new year.. hopefully that’ll solve it..
Thanks for your advice guys ..
Doubledave
