How to use forscan
How to use forscan
Postby loot » Wed Jan 03, 2024 12:56 pm
Any experts on here that know their way around forscan?
Particularly euro 6 2.0 adblu 2020 70reg transit cab mk8
Had a new clutch and done 1000 miles, it cut out while driving round a yard and wouldn't start.
I want to see if there is synchronisation between the cam and crank.
I've read a load of fault codes,cleared them and rechecked but only 3 come back that are low battery related.
Battery on charge for now. It is turning over and I can see the belt moving through the filler cap.
Need live data for fuel and sync ideally. Cheers
Ids map here
loot
Re: How to use forscan
Postby loot » Wed Jan 03, 2024 9:07 pm
I got it working on my laptop, my elm 327 is a few years old and forscan said it wasn't quite upto the job but I was able to read all modules and all codes. Anyway I got the van running after a battery recharge and lots of cranking . Seems like the nearly empty fuel gauge was misrepresenting £20 of fuel added. It starts spot on now.
Ids map here
loot
Postby Chug » Wed Jan 03, 2024 11:39 pm
Forscan added a not compatible warning for elm327's as there were so many cheap clones that didn't work, we always recommend Steve @ Tunnelrat, but if yours is reading all modules no worries just crack on.
and I just remembered I sent you a PM last month but I never got a reply :roll:
Chug
Postby loot » Thu Jan 04, 2024 10:27 am
Chug wrote:Forscan added a not compatible warning for elm327's as there were so many cheap clones that didn't work, we always recommend Steve @ Tunnelrat, but if yours is reading all modules no worries just crack on.
Really? Sorry about that I'll have a look I may have seen 2 at once I don't usually miss them, although I don't get notified unless I go into personal messages
Additional. I'm looking at the vlinker v2 it has auto switching etc cheers
Ids map here
loot
Postby loot » Thu Jan 04, 2024 10:33 am
Ids map here
loot
Postby Chug » Thu Jan 04, 2024 9:42 pm
Forscan recommend this one https://www.amazon.com/dp/B094Z7PBLS
Chug
Postby loot » Sat Jan 06, 2024 4:08 pm
That's the 1 I've ordered,if nothing else the auto switching between cans is a lifesaver :lol:
Ids map here
loot
