Running problems
Running problems
Postby Jcvan » Wed Jan 24, 2024 4:49 pm
Good afternoon, I have a Ford Transit 2010, I have a problem that I just think the German garages haven’t got a clue what it is , this is my problem: I can drive some days and nothing happens and then standing at traffic lights the engine runs up and down or when I am on a long journey the engine gives me no power. This is a list of things I have had done so far 1 new injections 2 new diesel filter 3. new agr 4 new dpf 5 new starter motor. 6 new alternator labels checked from starter to alternator 7 new oil plus filter. Is there anybody that can help me please thanking you john
Jcvan
Re: Running problems
Postby Airthies » Wed Jan 24, 2024 5:05 pm
If you have replaced the injectors?
I would change the SCV (suction control valve) and the PRV (pressure relief valve)
These will require the computer to carry out a "learn" process once valves are replaced and also a pilot pressure and pump learn should be carried out as well.
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Jcvan » Wed Jan 24, 2024 5:12 pm
Hi thanks for the reply, I think the garage did this as they put the injectors in for me , the also checked the computer bords
Jcvan
Postby knobby1 » Wed Jan 24, 2024 7:45 pm
Jcvan wrote:Hi thanks for the reply, I think the garage did this as they put the injectors in for me , the also checked the computer bords
As Airthies says, will be the SCV causing the "hunting idle". A set of learns often fixes it, failing that, replace the SCV and re run the learns. Poorly injectors will not cause a hunting idle.
Postby Jcvan » Thu Jan 25, 2024 7:57 am
Good morning I will try this today and let you know if it works thanking you john
Jcvan
Postby Jcvan » Thu Jan 25, 2024 3:02 pm
Hi after doing the relearning programs still no change I took the van out for a drive and when you pull away the van seems to rev up and down , when you sit at the traffic lights the motor revs up and down, i have also change the acceleration pedel to day.
Jcvan
Postby Jcvan » Thu Jan 25, 2024 5:19 pm
Do I have to reset the dcm after competing the learning programs ?
Jcvan
Postby Airthies » Thu Jan 25, 2024 5:23 pm
How high does it rev?
Check clutch switch isn't activating the "anti stall" function
Which raises engine idle rpm when clutch is pressed anticipating load when pulling away
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Jcvan » Thu Jan 25, 2024 6:17 pm
The reving and down ist very much I would say from stand 900. Rev to about 1400 and then sinks to 600 where is the clutch switch may I ask thanking you john
Jcvan
Postby Jcvan » Fri Jan 26, 2024 7:15 am
Good morning, I will order a clutch switch and let you know if it works . Thanks for now I hope next week it will be here thanking you john
Jcvan
Postby Jcvan » Mon Jan 29, 2024 5:18 pm
Good evening, clutch switch has arrived today , I will be putting it in tomorrow and let you know if it has solved the problem
Jcvan
Postby Jcvan » Wed Jan 31, 2024 8:58 am
Good morning clutch switch built in but it still has the same problem, I am going to change the sensors on the dpf and see what happens thanking you john
Jcvan
Postby Airthies » Wed Jan 31, 2024 9:15 am
What fault codes are you getting
And what diagnostics software are you using?
V86+patch
V86.04
X-Prog
C81
Airthies
Postby knobby1 » Wed Jan 31, 2024 8:41 pm
Jcvan wrote:Good morning clutch switch built in but it still has the same problem, I am going to change the sensors on the dpf and see what happens thanking you john
2010 is Euro-4 and won't normally have a DPF....unless you have one of the rare Euro-4's which someone has asked for it when new, it was an "option" on the Euro-4's from ~2008 I believe.
Postby Jcvan » Fri Feb 02, 2024 11:56 am
Good morning, Airthies and knobby 1, my van is 07.09.2010 (second hand) I didn’t know it was a option to have a dpf thanks for this info , I am waiting for the new peace’s to be delivered, which I hope will be soon so I can put them in and try again , I have done the Updates on forscan new updates which helps, at the moment I can give any info on how it’s going to be but I will let you know. Thanking you both at the moment for your help , I will let you know how it’s going thanking you john
Jcvan
