Engine tube help
Engine tube help
Postby Derekmurton » Wed Jan 31, 2024 11:31 pm
Hi I have this pipe on right hand side of engine bay not connected at bottom should it be ?
Derekmurton
Re: Engine tube help
Postby metalworker0 » Wed Jan 31, 2024 11:49 pm
Have a look at the lower half of the air box ..see if it connects to a pipe that sticks out ..i'm just quoting the set up on a connect that may be similar.
also ..always tell us the model of van you are talking about mk7 , mk8 , connect mk1 , mk2 etc..engines size, front wheel drive or rear wheel drive
or you'll not get any answers
Postby Frag » Thu Feb 01, 2024 12:21 am
Gearbox breather pipe,
Pipe Tends to split then fall off,(you can see it starting to do this at the top too.)
There will be a stub on top of the gearbox it should be fitted to.
Frag
Ford Technician
Postby Airthies » Thu Feb 01, 2024 12:31 am
Frag wrote:Gearbox breather pipe,
About to say exactly this
Can be replaced with a pice of fuel hose(oil resistant hose) for not many pennies
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Derekmurton » Thu Feb 01, 2024 10:59 am
Hi it’s a 2018 2l transit
Derekmurton
Postby Derekmurton » Thu Feb 01, 2024 11:01 am
I cannot see any stub that it fits to
Derekmurton
Postby Frag » Thu Feb 01, 2024 2:49 pm
Frag
Ford Technician
Postby Derekmurton » Thu Feb 01, 2024 6:41 pm
Thanks that’s really good I’ll take a look in the morning. What would happen if not connected ?
Derekmurton
Postby metalworker0 » Thu Feb 01, 2024 7:38 pm
You'd get water in your gearbox if you drove through a flood... and particles could fall directly into the gearbox through the tube connection point.
You also want to make sure the gearbox oil is changed every 50,000 miles, if you want it to last.
Postby Derekmurton » Thu Feb 01, 2024 8:48 pm
Thank you so much I’ve done 11000 miles don’t know how long been disconnected fo you think I should get gearbox oil changed now
Derekmurton
Postby metalworker0 » Thu Feb 01, 2024 9:38 pm
only if youve wadded through 14 inches deep or more of water .. don't think the Little hole will have pulled in much dirt in 11,000 ..its up to you ...you cant harm it ..well you can if you put the wrong oil in.
Postby Derekmurton » Thu Feb 01, 2024 9:52 pm
Thanks I’ll probably get done by dealer
Derekmurton
Postby Airthies » Thu Feb 01, 2024 11:16 pm
Is it front or rear wheel drive?
Earlier picture is a FWD box.
RWD the breather is top center of the box just behind the bell housing section.
Breather tubes are usually 90° plastic fitting similar to the top end so unlikely to have dragged in an excessive amount of water and debris unless it's completely missing or snapped with the opening upward.
I'm sure there's thousands of vans out there with breather pipes in similar states that are never rectified and still going with no decearnable issues.
I would rectify what you've found but not necessarily start panicking about it.
Sometimes you can worry enough to create problems.
V86+patch
V86.04
X-Prog
C81
Airthies
