battery change
battery change
Postby schott999 » Thu Feb 15, 2024 4:45 pm
hi lads ,it seems strange but both of my batteries will not hold a full charge i would like to change both but not sure how you are supposed to get to them under the seat, is there an easy way and am i missing something here, many thanks
schott999
Re: battery change
Postby Altransit » Thu Feb 15, 2024 4:50 pm
Taking the seat out is the easiest way to change them. I remove the 4x 13mm nuts at the front and back of the sliding rails, and tip the seat over on to the passenger seat :)
Re: battery change
Postby knobby1 » Thu Feb 15, 2024 9:29 pm
Altransit wrote:Taking the seat out is the easiest way to change them. I remove the 4x 13mm nuts at the front and back of the sliding rails, and tip the seat over on to the passenger seat :)
Exactly how I do it....only take a couple of mins.
Re: battery change
Postby schott999 » Fri Feb 16, 2024 11:55 am
thanks for the replies lads. is there a way i can tell which battery is totally shot rather than buy two?
schott999
Re: battery change
Postby dumper » Fri Feb 16, 2024 12:35 pm
From experience on twin battery setups 12/24 volt fitting only one new battery into the system will drag the new one down and seen it kill the new one many times
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: battery change
Postby knobby1 » Fri Feb 16, 2024 9:17 pm
schott999 wrote:thanks for the replies lads. is there a way i can tell which battery is totally shot rather than buy two?
Proper load test will tell you, replacing both will be the best option....but usually it's the front battery which fails first, it does most of the work. Best to swap them every 6 months or so to share the load.
