good evening all,
Can anyone please give a bit of advice on how to use Forscan to check if glowplugs are working?
Thank you
Simontfs wrote:good evening all,
Thank you
What model Transit..?? Mk6 or Mk7..?? Euro-3, 4 or 5..??
If they are working properly, you'll not see any fault codes. I'm not aware of any specific glow plug test within Forscan....but Forscan gets frequent software updates so it may have been introduced and I haven't seen it....has been quite a while since I last used it.
Forscan usually just gives a fault code for failed glow plugs, they're wired in parallel so it won't know which one is blown or if more than one are blown....they are often/usually shorted to ground and end up blowing the fuseable link near the engine bay fuse box.
Sometimes the glow plug power bus bar breaks at the power connection point due to corrosion or vibration etc... In that case you may get an "open circuit" fault.
