gsc1ugs wrote:That seems be ok, is there a relay?
gsc1ugs wrote:Thats clicking seems ok, i took starter off, tested on bench fine, put back on van, connected short terminal to positive and even though battery not fully charged, it turned engine, key still doing nothing…
Ive also swapped round relays under bonnet
gsc1ugs wrote:Anyone got next port of call? Starter turns engine, ignition isnt
gsc1ugs wrote:No codes, just no turn over at the key, hitting positive at the starter striking engine turns, want eliminate ignition at the ignition switch so its like eliminating key or in a crude word as though im stealing it
knobby1 wrote:
It's the switch on the back of the ignition barrel...very easy to change to eliminate it...10-15 quid will see it sorted...very common fail point on the Transits.
Users browsing this forum: meh
