MK7 Locking issue
MK7 Locking issue
Postby Elsaetka » Wed Feb 28, 2024 9:55 pm
Hello,
Hope someone can help with what on the face of it seems a simple issue but I can't get past it.
My MK7 standard 2.2 SWB van does the common horn honk when I lock it. I changed the rear door lock and loom (it's a single up and over door model.
I noticed that it doesn't put a light on to show the side door is open, so I changed the side door lock and actuator, plus I fitted brand new door contact pins and plate, still no luck.
Any feedback on what this is would be appreciated.
Thanks in advance.
Elsaetka
Re: what have u done today?
Postby Airthies » Thu Feb 29, 2024 7:25 am
Have you checked your fuses?
Did you change the loom and locks for new or S/Hand?
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Re: MK7 Locking issue
Postby Elsaetka » Thu Feb 29, 2024 10:39 am
Hi,
The rear lock and loom are brand new, the side door lock was a used one, only because a new one is expensive.
I do have a new solenoid, but i'm guessing the advice is going to be, fit a brand new side door lock. All of the fuses are 100% fine.
Elsaetka
Postby Elsaetka » Tue Nov 26, 2024 9:19 pm
The van has code B10E4 rear door double locking relay short to ground.
I can't tell which relay this refers to, I've seen posts saying this is caused by a faulty BC, but I don't want to go down that route if the fault is just a relay.
Any advice would be appreciated
Elsaetka
Postby Airthies » Tue Nov 26, 2024 9:26 pm
Check your door harness I know you said you'd previously fitted new but don't overlook it. Also the lock, especially if they were cheap eBay specials?
Side door open signal is an old fashioned push switch down on the lower right door pillar below the lock contacts.
Locking relays are mounted directly to the BCM circuit board.
V86+patch
V86.04
X-Prog
C81
Airthies
Users browsing this forum: knobby1, Majestic-12 [Bot]
