Mk6 dash clock issues
Postby hodgy » Sat Mar 02, 2024 5:18 pm
Hi I have a mk6 transit 06 reg with dash clock issues,no temp,speedo,rev counter I have tried 2 other sets that worked but still not working there is a few connecter plugs behind dash that are not connected to anything also one coming.off the main speedo wiring aswell any advice on this issue would be greatly appreciated thanks chris
hodgy
Re: Mk6 dash clock issues
Postby Airthies » Sun Mar 03, 2024 4:56 pm
It didn't previously have a tacho fitted?
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby metalworker0 » Sun Mar 03, 2024 7:16 pm
Would imagine that for your year stated, there may have been some transits that worked the speedo off the ABS system and some that had a sensor on the gearbox.
and you got the wrong speedos
Postby knobby1 » Sun Mar 03, 2024 8:44 pm
metalworker0 wrote:Would imagine that for your year stated, there may have been some transits that worked the speedo off the ABS system and some that had a sensor on the gearbox.
"ALL" Mk6's use a gearbox speedo sensor...only Mk7's and later use the ABS system for the speedo.
Postby hodgy » Sun Mar 03, 2024 10:21 pm
It's never had a tacho fitted,it's a recovery truck twin axle,the clocks I put in worked in the van they came out of but don't work in mine. Apparently this is a common fault,the mileage comes on when ignition turned on on then just the lines,the rev counter,speedo and temp gauge all move from resting position but that's it they dont move anymore.he told me that there are multiple earth's under dash which break off from spot welds?
hodgy
