2.4 2008 Wastegate link broke
Postby aseriestipper » Sun Mar 03, 2024 7:20 pm
Seems to be common, the pin that goes through the actuator arm has come off the wastegate lever, is there a site I can find the turbo and wastegate part numbers as it may be easier to get a used turbo and wastegate to put on?
aseriestipper
Re: 2.4 2008 Wastegate link broke
Postby aseriestipper » Sun Mar 03, 2024 7:22 pm
just an update, I have a guy who knows a breaker that keeps " known quality parts" rather than chance fleabay so I am guessing the part numbers would be a must to match up.
aseriestipper
Postby Airthies » Sun Mar 03, 2024 7:53 pm
I welded the pin back on our van way back around 2014 still going
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Airthies » Sun Mar 03, 2024 8:53 pm
Also Check the bolt in the exhaust snail clamp from turbo core to snail.
A mates bolt let go and turbo came loose, core was in good nick other than exhaust impeller got worn so when refitted the clamp it had no puff.
Ended up needing to fit a complete turbo.
V86+patch
V86.04
X-Prog
C81
Airthies
