Have to open sliding door with 2 hands Mk 7
Postby Jimbo2502 » Tue Mar 05, 2024 2:17 am
When opening the sliding door from outside I have to put 1 hand behind the rear of the door and pull it out then pull the handle back to open.
Same with inside slight push outwards then slide the door open.
Really annoying as I pick people up in the minibus and have to keep getting out to let them in showing them the knack.....Also it has to be slammed really hard to close of use 2 hands 1 to pull handle and other to push side of door in.
Please could you help me as I've looked all over for a fix.
Jimbo2502
Re: Have to open sliding door with 2 hands Mk 7
Postby Airthies » Tue Mar 05, 2024 8:06 am
Replace the rollers.
Don't buy cheap spend the extra for genuine if your running it as a minibus
Sent using crapatalk
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Jimbo2502 » Tue Mar 05, 2024 9:39 am
OK thank you Airthies I'll have a look for them.
Jimbo2502
Postby andz327 » Wed Mar 06, 2024 3:35 am
Middle Roller is sprung, wd40 it until it doesn't stick, if spring broke do ad Airthies said
andz327
