youngblood wrote:I have a 2015 transit custom 2.2 the service light started coming on and loss of power I used to switch it off and start it again and it would run fine. But it was happening a lot more, now it won't rev up service light comes on and a symbol with tyre tracks lights up like slippery road, as long as you don't touch the throttle its fine engine start first time. I plugged in a diagnostic machine in from a friend and it came up with throttle pedal sensor bad so I brought a new throttle pedal and fitted it cleared the codes and it still says the same thing do you have to do something for the new pedal to work?? I have attached the code?? any idea what else it could be.
Users browsing this forum: Lordduvet
