Got a Transit lwb high roof 2.4 l rwd 2011
Any help would be much appreciated
metalworker0 wrote:1. Master cylinder piston travels to areas its never travelled to , so buggers the seals when you use the pumping pedal method ..so you might have a failed master cylinder now.
or
2. If you have ABS, the abs has to be activated into bleed mode by the forscan software to get the air out of it .
or
3 If it does not have ABS it may have a brake proportional valve, that act up or fail when they get old
4. Your bleed method by pumping pedal isn't doing the job and you need a Gunsons Eezybleed..that pressurise's the master cylinder with the air out of your spare tyre, a tried and tested "CHEAP" device that I have used for years and it's never let me down ..if that does not work ..you are buying a new master cylinder .
Transit MK7 wrote:Would you know if this is the case on a 2011 mk7 transit ?
Like I said regarding rear pads , the nib on the pad needs to be int the groove othe piston when caliper slides back on for rear brakes to self adjust and can give spongey feel, if you have Forscan ( or scanner that bidirectional control) you can bleed your system using your laptop(or scanner)which operates abs pump to bleed the whole system......, what is condition of brake disks?? Badly scored or worn discs may need pads to bed in for pedal to get betterTransit MK7 wrote:My brakes were pretty spungy after changing the pads so thought it would be good to bleed them. We’ve used the easybleed system which hooks up to the spare tyre pressure. I’ve watched a couple videos and it sounds like I’ve probably blown the rubbers on the on the master cylinder. I’ve ordered a new one so hopefully that’ll fix it. I believe it does have abs system so will look into that as well.
Thanks for the help guys anymore is much appreciated.
