I have top up the oil with Mannol 5w-30.
I am not sure if that makes the difference but when I drived on lpg the van started to losing power and I heard very little shots/explosion sounds. When accelerated it feel like Im on to high gear.
I started to drive on petrol and everything was normal. After while the van wasn't powerful as before and struggled to gain the speed up to 60mph. I searched the internet and found that the fuel injectors might be clogged and need cleaning/changing.
When i opened the bonnet I discovered oil leaked as you can see on the pictures.
Could anyone advice what is the issue and is it worth fixing or just get rid of?
Best regards
