Found a Spring in sump?
Postby Rogsvan » Thu Apr 04, 2024 7:39 pm
2.2 rwd 2015 van , new to me van so pulled sump to check strainer while changing my oil all good apart from this spring and two rubbers sat in the bottom of the pan. Van runs and drives good , any ideas what could have failed? Oil pump looks good with the bigger spring still in it.
Rogsvan
Re: Found a Spring in sump?
Postby metalworker0 » Thu Apr 04, 2024 8:04 pm
the orange rubber things - They are from the underside of the rocker cover .
not sure if you can buy them separately.
rumour has it, they fall out when the engine has a blowing injector seal. !
the spring don't know
Postby metalworker0 » Fri Apr 05, 2024 1:05 pm
There are no pictures anywhere on the net, of what the little spring looks like, that's inside the timing chain tensioner
so cant confirm it, as that ..unless someone with the knowledge here ..says it is it
Postby sherwoodcycles » Fri Apr 05, 2024 6:08 pm
If I get to bicester soon, I have an old one - I'll cut it open and see. ....if it's not been cleared away
Greeny
sherwoodcycles
Postby sherwoodcycles » Fri Apr 05, 2024 6:19 pm
viewtopic.php?f=5&t=221433
This thread is about a spring being found (a smaller one) but may be useful to give you ideas.
Greeny
sherwoodcycles
Postby Rogsvan » Sat Apr 06, 2024 9:40 pm
Thanks for the reply and the offer to chop one up!, looks far to flimsy for a tensioner spring i woulda thought but i usually work on bikes so not to sure what the tensioners are like on these. Some one said oil pressure relief like on the other thread but even that is a much heavyer gauge spring. Pcv valve assembly was suggested not sure what they look like internally ?
Rogsvan
Postby knobby1 » Sat Apr 06, 2024 10:16 pm
Rogsvan wrote:Thanks for the reply and the offer to chop one up!, looks far to flimsy for a tensioner spring i woulda thought but i usually work on bikes so not to sure what the tensioners are like on these. Some one said oil pressure relief like on the other thread but even that is a much heavyer gauge spring. Pcv valve assembly was suggested not sure what they look like internally ?
They don't have a PCV valve, so it won't be that. They're a petrol engine thing.
Postby sherwoodcycles » Mon Apr 08, 2024 2:11 am
Clutching at straws but could it be a valve tensioner spring like in this pic? Or is it smaller?
Greeny
sherwoodcycles
Postby sherwoodcycles » Mon Apr 08, 2024 2:12 am
It's a different engine but just a thought.
Greeny
sherwoodcycles
Postby sherwoodcycles » Mon Apr 08, 2024 2:20 am
Or an oil pressure valve spring if there is one in your engibe ?
Greeny
sherwoodcycles
Postby metalworker0 » Mon Apr 08, 2024 1:08 pm
wonder if this black thing in the ford hardware kit .. has this spring on it when installed ... it just looks ready to take that spring
https://www.ebay.co.uk/p/23022909924
Postby sherwoodcycles » Mon Apr 08, 2024 6:50 pm
Or...it could be that the previous owner was fitting those orange bungs and writing down which holes he had put them in. He might have been so stressed doing this, that he kept clicking the pen he was using to write down the locations. The pen may have been made out of low quality plastic and broken, resulting in the spring striking the previous owner on the top lip below the nose (it really hurts) causing him to drop the remaining orange bungs and letting the spring fall into the engine.
Greeny
sherwoodcycles
Postby metalworker0 » Mon Apr 08, 2024 7:50 pm
Someone else found these orange bungs far away from where they should be, in an engine strip just over a week ago,. on the m8 forum.
viewtopic.php?f=64&t=227221
that spring is bigger than a biro spring , but smaller than a valve spring
on the parts diagram, i see a tensioner blade for the oil pump chain ..but don't see a spring or any the means for it to make tension ?
Postby sherwoodcycles » Mon Apr 08, 2024 9:14 pm
I guess you could lift the cover and see if they're missing?
Greeny
sherwoodcycles
Postby martyb123 » Fri Aug 08, 2025 5:32 pm
Hi,
Sorry to bring this up again but I have just got the same on a 2.2 2015 RWD transit. Did anyone find out what the spring is from ?
martyb123
