Cambelt pulley bolt torque 2.0 ecoblue
Postby Reddiamonduk » Fri Apr 05, 2024 2:37 pm
Does anyone know the tightening torque for the bottom cambelt pulley on the 2.0 ecoblue engine.
It started to rattle and then stopped completely within 20 seconds whilst driving.
Reddiamonduk
Re: Cambelt pulley bolt torque 2.0 ecoblue
Postby metalworker0 » Fri Apr 05, 2024 3:58 pm
rattle on start up could be normal for drained oil pump or if you've done major work on it dismantling oil system. otherwise not good
not sure how cambelt tensioner works on these , if it were a chain system you'd have a hand grenade type pin to pull out of the tensioner.
The only issue i can see is ..you have to have a huge breaker bar to do up the nut on the crank. as you can see : 3/4 drive ..possibly with extension on it for final pulls
Stage 1 20nm
Stage 2 40nm
Stage 3 90 degrees
Stage 4 90 degrees again
Stage 5 90 degrees a final time)
So from stage 4 takes considerable force to do ..so you need very hefty 3/4 drive socket and breaker bar.
There is no keyway on the crank pulley ..hence the tightening sequence with new nut.
the new nut will probably have a built in washer or washer with diamond dust impregnated into it. one time use only
You can't re-use the timing cover, the sump will have to come off to replace the wet type oil pump belt.
Postby Reddiamonduk » Fri Apr 05, 2024 4:08 pm
Thanks but it's not the crankshaft pulley. The crankshaft drives an idler pulley that the cambelt is driven from, it's the idler pulley bolt that I need the torque settings for as mine snapped whilst driving so I have to replace it.
Reddiamonduk
Postby metalworker0 » Fri Apr 05, 2024 4:58 pm
sorry - no luck ..searched and found only the videos on youtube
so put in "ford transit ecoblue belt change" ..and hope that some one mentions it on the half dozen videos there are of it .
Postby Reddiamonduk » Fri Apr 05, 2024 7:42 pm
I've looked everywhere online but can't find it. I even asked Ford when I bought the new bolt but they said they can't access the setting unless the job is booked in with them :cry:
Reddiamonduk
Postby metalworker0 » Fri Apr 05, 2024 7:56 pm
well the only thing you can do then is ID the bolt grade
https://www.dgmfmoldclamps.com/wp-conte ... o.-Ltd.jpg
according to the first pic you posted its 10.9
see here on the max torque that bolt is permitted...you must measure the bolt thread diameter (shank) not the bolt head, eg .. m20 has 20mm shank
https://fractory.com/metric-bolt-torque-chart/
read here more about bolt toques and how to work out a fair torque for it
https://www.dgmfmoldclamps.com/what-are ... lt-grades/
Postby Reddiamonduk » Fri Apr 05, 2024 8:36 pm
It's bolt HB1 in this diagram.
You are correct it is a 10.9 bolt, thanks for those links, it looks like I'll be working it out from there as I don't think it's actually listed anywhere online.
Reddiamonduk
Postby metalworker0 » Fri Apr 05, 2024 8:40 pm
found this ..still isn't listed
but different 9 stage crank bolt tightening - assuming you have a 300Nm torque wrench.
https://www.vinnybyrne.com/view_pdf.php ... 251429.pdf
Stage 1: Tighten to 10 Nm.
Stage 2: Slacken 60°
Stage 3: Tighten to 20 Nm.
Stage 4: Tighten to 70 Nm.
Stage 5: Tighten to 150 Nm.
Stage 6: Slacken 90°
Stage 7: Tighten to 100 Nm.
Stage 8: Tighten to 300 Nm.
Stage 9: Tighten by 90°
Postby Reddiamonduk » Fri Apr 05, 2024 9:38 pm
Yeah I saw that, NINE f*cking stages to tighten a crank bolt, what were they thinking when they decided on that ffs :lol: :lol:
My broken bolt happened 4 weeks after changing the cambelt, but you don't even need to remove that pulley so I never checked that bolt.
https://youtube.com/shorts/X0t1v9sR2tY?feature=share
Reddiamonduk
Postby metalworker0 » Tue Apr 16, 2024 8:09 pm
from the ford workshop manual; posted today in the custom forum
fuel pump sprocket bolt
stage 1. 25 nm
stage 2. 75 nm
all the best ..mark
Postby hi_tower » Sun Apr 21, 2024 10:53 pm
Stage 1- 60nm
Stage 2- Loosen 90deg
Stage 3- 20nm
Stage 4- 45nm
Stage 5- 45deg
For a standard bolt according to the Ford manual.
hi_tower
Postby hi_tower » Sun Apr 21, 2024 11:05 pm
Sounds like the thin sprung wheel has come off the back of the idler pulley when you changed your wet belt. The thin wheel can rattle around behind the idler pulley until it goes behind it and breaks the bolt. There’s another sprung wheel behind the fuel pump wheel that will be loose now as well.
hi_tower
Postby hi_tower » Sun Apr 21, 2024 11:25 pm
If the idler wheel has broken off while you were driving chances are your engine is going to be pretty badly damaged by the pistons hitting the valves.
hi_tower
Postby lee7777 » Wed Aug 21, 2024 11:19 am
Good morning guys.
The camshaft belt gear bolt has recently broken on mine after i replaced the timing belt.
This is something know to Ford so i would advise you get in touch to your local Ford dealer so they can raise a GCR (global concern report)
The more cases raised the the more Ford engineering will look into the fault.
lee7777
Postby lee7777 » Wed Aug 21, 2024 11:31 am
Good morning.
This has recently happen to my 2l ecoblue after replacing the timing belt.
This is a known concern with the timing gear pulley bolt breaking.
You need to contact you local for dealer and get them to raise a GCR (Global concern report)
The more Ford are aware of the quicker and more likely Ford engineering will look in to it.
lee7777
