How to remove - replace security locks - Not Locked, No Key
Postby Colink2 » Wed Apr 10, 2024 12:00 pm
I have purchased a van with security locks. The locks are unlocked but came with no key. Same as this lock https://www.vantagevcltd.co.uk/wp-content/uploads/2016/02/33.jpg
I assumed that I would drill the rivets on the outside, remove the cylinder and fit new cylinders.
The manufacturer tells me I need to get a locksmith to do the work otherwise I may damage th evan. (They know they are unlocked).
Any comments / advice?
Colink2
Re: How to remove - replace security locks - Not Locked, No
Postby bortaf » Fri Apr 12, 2024 7:31 pm
For a start i'd have asked exactly why a non locksmith removing them would damage the van :? seems a very vauge sweeping statment to me, a sort of covering thier arses cos they don't know the answer kind of statment ???
you may need to turn the lock to aline the latch with hole to remove it, like euro house door locks ???
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Altransit » Fri Apr 12, 2024 7:42 pm
bortaf wrote:you may need to turn the lock to aline the latch with hole to remove it, like euro house door locks ???
Isn't that why you need to key to remove the lock? It's a while since I did mine, but I seem to remember having to turn the key partially to line up two tabs so it can be extracted. Otherwise the lock needs to be drilled out from the barrel :?
