2021 Ford Transit Trail 350 Fwd 170 - P1102 Mass Airflow
Postby TransitTrail170 » Sat Apr 13, 2024 6:59 pm
Good evening all,
After some advice before I go insane :-(
I have a 2021 Ford Transit Trail 2.0 ecoblue 170hp, I had the turbo & dpf go in October 2023 ever since then I'm having issues with engine code P1102 mass air flow lower than expected. Parts that have been changed throttle body, all hoses, numerous maff & map sensors, egr, cooler, intercooler....etc
The mass air flow rate is dropping to zero when not on throttle which is putting code p1102 on in the background but no engine light on, then engine goes into limp mode with very little acceleration. I've attached live data reading for the mass airflow showing it drop to zero when not accelerating.
Van has been into Furrows Ford & another reputable local garage and neither can sort the problem.
Any insight to this problem would be much appreciated as this is costing me a fortune & borderline going bust if the bills keep mounting up.
Regards
Craig
TransitTrail170
