wet rocker seals
wet rocker seals
Postby bazaducato » Sun Apr 14, 2024 5:02 pm
I would also appreciate any help on the breather system. i dont think i have leaking injector seals but i do have some blow by around the injector seals on top of the rocker cover, and a little smoke when removing the oil filler cap. any info or diagrams or info on the rocker cover breather would be very helpful. Thanks
bazaducato
Re: wet rocker seals
Postby knobby1 » Sun Apr 14, 2024 8:14 pm
bazaducato wrote:I would also appreciate any help on the breather system. i dont think i have leaking injector seals but i do have some blow by around the injector seals on top of the rocker cover, and a little smoke when removing the oil filler cap. any info or diagrams or info on the rocker cover breather would be very helpful. Thanks
You've not told us what model Transit you have..?? Mk6 or Mk7..?? FWD or RWD..?? Euro-3, 4 or 5..??
Postby andz327 » Sun Apr 14, 2024 8:29 pm
With ducato in his name I'm guessing it's Fiat with the puma under the bonnet ma lord....
Blow by the injector compression seals is what causes Blow-by around the cam cover seals, pull the breather hose off cam cover and see if its blowing out the cam cover...if it is then breather not blocked
andz327
