Ah yeah sorry, missed the 1989, it has the 2L ohc engine then?
Try this
https://www.catcar.info/ford/?lang=en&l ... Y0NzA4OCswI don't think it will be a straight swap, I think you'll have to fabricate/weld to join them, but you could be lucky, you'll have to compare what you've got with the diagrams, if you click on "F04 Engine Assemblies Mounted On Body.Exhaust System And Heat Shields" at the top of the page it will take you back to the menu to see the other ohc versions.
