Check for blown fuse as faulty unit may have blew it, don't know what one but easy enough to check both interior fuse boxes behind glove boxandz327 wrote:Does the actuator work when it's off the heater ? Is it new? Are the spring, arm and rod on properly
andz327 wrote:Check for blown fuse as faulty unit may have blew it, don't know what one but easy enough to check both interior fuse boxes behind glove boxandz327 wrote:Does the actuator work when it's off the heater ? Is it new? Are the spring, arm and rod on properly
neilyp wrote:andz327 wrote:Check for blown fuse as faulty unit may have blew it, don't know what one but easy enough to check both interior fuse boxes behind glove boxandz327 wrote:Does the actuator work when it's off the heater ? Is it new? Are the spring, arm and rod on properly
Yes it’s a new actuator - spring is in the right position, the spring auto closes
the flap it seems. I am guessing that’s right
andz327 wrote:Yeah but think the arm it goes on can be fitted wrong way
