What do we think the fault causing this noise is?
Postby Abbadon » Tue May 21, 2024 3:19 pm
A noise, internittent, most common when driving after car has sat and everything is "cold". Smaller clicky/clunks are audible when you have driven a bit. Have limited time to diagnose, supposed to be driving my family to the airport next week, so this is really non ideal timing.
I have uploaded a video where I captured the worst the noise gets.
https://youtube.com/shorts/g4GOVNa-o3M? ... DdB9T9qa74
After I drove a few minutes, it doesnt re occur, but i expect when cold it will again. One place thought cv joint, and that area is getting warm on back of that hug/cv boot area. But another doesn't think this is a CV noise!
Abbadon
Re: What do we think the fault causing this noise is?
Postby metalworker0 » Tue May 21, 2024 3:28 pm
microphone is either distorting it really badly ..or it sounds like the exhaust leaking.
Postby Abbadon » Tue May 21, 2024 4:17 pm
It's definitely not exhaust, it's metallic crunch/creaky/god awful noise.
Abbadon
Postby knobby1 » Tue May 21, 2024 8:06 pm
Abbadon wrote:It's definitely not exhaust, it's metallic crunch/creaky/god awful noise.
Loose heat shielding under the van..?? Between exhaust and fuel tank..??
Postby Abbadon » Tue May 21, 2024 9:24 pm
No, it's much stronger than just a rattling shield, it's really load and nasty noise.
Abbadon
Postby metalworker0 » Tue May 21, 2024 11:08 pm
well its the distorted sound ..really cant tell
does it sound like this
https://www.youtube.com/watch?v=fN91L4WsyMM
all the best..mark
Postby andz327 » Wed May 22, 2024 2:23 am
Does it dissappear in the wet??
Could be a dry creaking /worn ball joint
andz327
