Will Transit mk7 engine fit in mk8
Postby Brian1987 » Sat May 25, 2024 8:47 am
Hi
I have a 2016 mk8 transit 2.2 euro 5 that has blown 2 reconditioned engines. I have a very low mileage 2010 mk7 2.4 6 speed that the body is rusted on. Is it possible to fit the engine from the mk7 2.4 into the mk8 2.2?
I will have both the vehicles beside each other so i can swap whatever bits i need. Has anyone done a similar engine swap and is there much modifications to do?
Brian1987
Re: Will Transit mk7 engine fit in mk8
Postby metalworker0 » Sat May 25, 2024 12:30 pm
its the ecu and emissions stuff that will cause the bother, your ecu is set up for a 2.2 including the coded injector learns and probably pile of other stuff ..it will not be a strait swap.
Postby Brian1987 » Sat May 25, 2024 3:19 pm
Hi Mark.
Would it be possible to fit the ecu from the mk7 2.4 into the 2.2 mk8. I will have everything to do a swap.
Brian1987
Postby metalworker0 » Sat May 25, 2024 4:42 pm
well until more knowledgeable people come along
i did a google search on this forum posing the question...because impossible to search here with the phrases i was using
here are the results ..if this works...as i cant get tiny url to work with it, and its a a 1000 character url
https://www.google.co.uk/search?q=ford+ ... nt=gws-wiz
if it does not, put into google this:
"ford transit forum 2.2 to 2.4"
all the best.masrk
Postby knobby1 » Sat May 25, 2024 10:22 pm
Brian1987 wrote:Hi Mark.
Assuming both are RWD, it should be possible, you don't say if the 2.2 is RWD or FWD...but.... "everything engine and engine control" related from the donor Mk7 vehicle will have to go into the Mk8. "All" engine and dash looms, PCM, BCM and all the other modules. Exhaust will be totally different, the 2.4 won't have a DPF, the 2.2 will. The 2.4 will be Euro-4 and the 2.2 will be Euro-5.
I'ts doable but not just a simple engine swap job.
Postby Viperover » Mon May 27, 2024 9:16 am
Brian1987 wrote:Hi
Hi, keen to know its blown 2 motors, what was the cause of failure on the original engine....
Viperover
Postby knobby1 » Thu May 30, 2024 10:13 pm
Viperover wrote:
Brian1987 wrote:Hi
Being Euro-5 is the major cause...their fuel system leaves a lot to be desired....some are well known for torching pistons....and some last well.. :?
Postby reaperkinqs » Mon Sep 15, 2025 9:45 am
I have a 2.4 mk8 running and driving
reaperkinqs
Postby reaperkinqs » Mon Sep 15, 2025 9:46 am
I have the 2.4 running standalone just in the process of making the dash work
reaperkinqs
Postby knobby1 » Mon Sep 15, 2025 9:46 pm
reaperkinqs wrote:I have the 2.4 running standalone just in the process of making the dash work
Since it's in a Euro-5 Mk8....Doesn't it have to meet Euro-5 emissions requirements...?? The 2.4 will never do that and the 2.4 never had a DPF either.
