Ford Transit Rocker Cover Replacement
Postby Jimxeo » Sat Jun 08, 2024 5:26 pm
Hi all.
I’m trying to find information on the Transit mk8 rocker cover. I am having presssure in the engine bay and trying to find out if this could be linked to the rocker cover.
I’m also wondering why they sell the rocker cover replacements allover the shop? Is it a known fault point on the engines.
Thanks!
Jimi
Jimxeo
Re: Ford Transit Rocker Cover Replacement
Postby metalworker0 » Sun Jun 09, 2024 10:09 pm
The rocker cover also belongs to older engines than yours, if the injectors need service i think it has to come off ..and if its 18 years old as it could be, its going to crack because plastic will be brittle after all those years
There are many posts here about leaking injectors seals making the pressure ..so maybe do some reading .
Note; when you post, we need to know your engine size and if RWD or FWD in order to give you an complete answer.
Postby knobby1 » Mon Jun 10, 2024 12:31 am
metalworker0 wrote:The rocker cover also belongs to older engines than yours, if the injectors need service i think it has to come off ..and if its 18 years old as it could be, its going to crack because plastic will be brittle after all those years
Mk8 will only be 10 years old at best.
Postby knobby1 » Mon Jun 10, 2024 12:33 am
Jimxeo wrote:Hi all.
Thanks!
Jimi
You've not told us what Mk8 engine you have..?? 2.2L Puma Euro-5 or 2.0L Panther Euro-6..?? FWD or RWD..??
Postby metalworker0 » Mon Jun 10, 2024 12:35 pm
yeah i was just saying how old the rocker covers could be if cracked and why they are on ebay...
