Simontfs wrote:Good afternoon everyone, so I have just received this part to try and resolve the idle issue I have, I believe it's called the scv that is on the side of the fuel pump, as the van keeps cutting out on idle once the engine is up to working temperature. Can anyone please give me some step by step guidance on the correct way to swap this part out. If it's a straight unbolt the old one and bolt the new one in, then that would be even better.
andz327 wrote:As our esteemed learned Laird knobby has mentioned fwd easy and hope it's a genuine part
Simontfs wrote:Good morning guys, thank you for your replies.. you are correct it is a FWD as in the signature on my post. I can confirm it's a Denso piece that I have bought. I believe I can handle removing a couple of bolts and replace the piece, but what has me a bit concerned are the learns. I have the latest version of forscan and a usb adapter specific to forscan and also registered and activated the extended license. Would one of you lovely people be able to guide me with what the correct order for the learns are, and please guide me with how to do them, what are the consequences if a learn fails? ...thank you so much for your time and patience.
