Mk7 side marker bulbs?
Postby OfficiallyColin » Mon Jun 17, 2024 5:50 pm
My searching has come up fruitless.
What bulb type goes in the little amber side markers down the side.
Not the indicator under the mirror.
I have no idea what the hell I’m doing.
2006 MK7 115 T350L
OfficiallyColin
Re: Mk7 side marker bulbs?
Postby knobby1 » Mon Jun 17, 2024 8:05 pm
OfficiallyColin wrote:My searching has come up fruitless.
Jumbo's are the only Transits which use the side markers....you must have a Jumbo..?? Just pop one of the lenses off and match the bulb at your local parts place.
Postby OfficiallyColin » Mon Jun 17, 2024 8:10 pm
knobby1 wrote:Jumbo's are the only Transits which use the side markers....you must have a Jumbo..?? Just pop one of the lenses off and match the bulb at your local parts place.
Yes, I should have said it's a jumbo. But it's fitted with cheap broken LED things so I can't check the bulb.
I have proper fittings on the way, which I'm going to use LED bulbs rather than a sealed unit that gets binned when it dies.
It would be handy to have the bulbs ready to go but I'll just have to wait and order the proper bulb when the fitting arrives.
2006 MK7 115 T350L
OfficiallyColin
