Van hesitates as if no fuel is getting through
Postby adam88binks » Mon Jul 22, 2024 2:56 pm
Hi everyone.
I have a Mk6 2.0tddi and its problem is getting worse.
When driving along the engine will stutter and hesitate for a split second then Carry on like nothing is wrong.
No fault codes showing on ForScan.
All lights extinguish immediately.
I've added a picture to show which lights come on whilst it hesitates.
I've replaced the fuel filter.
Any suggestions would be appreciated. I'm thinking fuel system?
adam88binks
Re: Van hesitates as if no fuel is getting through
Postby knobby1 » Tue Jul 23, 2024 12:45 am
adam88binks wrote:Hi everyone.
Looks like your glow plug light is on....this doubles as a DTC light....what cable are you using to read the codes..?? Latest version of Forscan will only work with a couple of specific cables.
Postby adam88binks » Wed Jul 24, 2024 6:22 am
adam88binks
Postby adam88binks » Thu Jul 25, 2024 5:17 pm
So ive ordered the OBDLink EX. hoping this one works. Ive had no luck with the ELM327 or Vgate vLinker FS OBD2 USB Adapter for FOR-Scan HS/MS-CAN Auto Switch
adam88binks
Postby knobby1 » Thu Jul 25, 2024 10:24 pm
adam88binks wrote:Hi LK
im using the VGate Vlinker
https://www.amazon.co.uk/dp/B0952P4MLP? ... ct_details
Should work ok with the V-Gate cable.
Postby adam88binks » Mon Jul 29, 2024 9:16 pm
SOLVED!!!!
So the van got the point of being undriveable. Electrics kept cutting out and I'd have to bang the dash to bring it back to life. My biggest clue was the blowers, these would stop working when the van was in fault. So I removed the entire dashboard so I could inspect the wiring as I knew this has to be the problem.
Found 2 corroded/old earth points that were on the same circuit as the blowers. Cleaned these up with sand paper until super shiny and reconnected the to the body. Cleaned both the crimp rings and removed the paint from the body work.
It's now been 2 days without a single issue.
Thanks to everyone for their help.
adam88binks
Postby knobby1 » Mon Jul 29, 2024 11:14 pm
Well done Sir....And thanks for getting back to us with your fix.. It does help others.
