LPG not running write
Postby Chessblue67 » Tue Jul 23, 2024 11:27 am
Hi new to this I have a transit on a 2003 it’s a 330 2.3 petrol lpg I believe the filter or filters need changing on the lpg where can I locate the said filters and best place to purchase them also I believe it’s a Ford fitted system from the factory thanks diagram would be good
Chessblue67
Re: LPG not running write
Postby metalworker0 » Wed Jul 24, 2024 12:36 am
if ive found the right diagram
https://www.catcar.info/ford/?lang=en&l ... I2NA%3D%3D
right at the top is the filter . item number 5
ford part number
1144796
put that part number into ebay
two results out of 19 other things
both £12
in the "cat car info" link above, see item number 3 .."Distributor" ..likely contaminated with tar like substance and needs disassembly and clean Probably obsolete, no seals available..so be careful.
