Mk6 2.4 90ps duratorq TDDI sudden rough idle/knocking
Postby nickax » Wed Aug 21, 2024 9:32 pm
Hi chaps (and chapesses)
My low mileage, but ageing 2003 bus-camper conversion has suddenly started playing up
For a while, I’ve had a nagging feeling it was a bit down on power, but a couple of mornings ago I went to start it and although it started instantly, was very, very rough, firing on three maybe, then stalling after a few seconds
Revving it a bit I can keep it running but it sounds terrible,
Tried again a few times over the last couple of days and still bad … one evening I took out the air filter which was damp .. and was able to drive it around the block, once warm, the idle was stable but there was still a bit of a knock.
Dried the air filter in a low oven and reinstalled the following morning, and were back to terrible running and stalling on tick over.
I can’t see any splits or cracks in hoses, they seem generally to be in very good Nick
I have ordered a new fuel filter as it’s due anyway … don’t really know where else to look
We had it on a very cheap and nasty ODB2 reader and it wasn’t giving any codes
Is there a diagnosis checklist somewhere ?
Do these have a fuel pressure regulator .. sorry, I am clueless
Thanks in advance
nickax
Re: Mk6 2.4 90ps duratorq TDDI sudden rough idle/knocking
Postby knobby1 » Wed Aug 21, 2024 11:15 pm
nickax wrote:Hi chaps (and chapesses)
Thanks in advance
Your OBD-2 reader is useless on a Mk6, they are "NOT" OBD-II compliant and 99% of the newer readers won't work. The Mk6's are EOBD. You need Forscan on a Windoze laptop and one of their compatible cables.
https://forscan.org/download.html
Postby dieseldel » Wed Aug 28, 2024 11:51 pm
hi
i think i wound start with fuel pump timing solenoid
it was like that before i touched it !!
dieseldel
Postby knobby1 » Thu Aug 29, 2024 7:44 am
dieseldel wrote:hi
He hasn't been back since he posted....we'll probably never know. He joined the forum in 2018 and only has 10 posts total since then.
