Error Code B153B PTC Heater circuit current above threshold
Postby dannykater » Thu Aug 29, 2024 7:13 pm
Hello!
I'm getting Error Code B153B PTC Heater circuit current above threshold in my Carly App, but can't find any information about this error?
What does the PTC Heater do? Found this:
PTC heater system in some cold climate countries to solve this problem. This system consists of an electronically controlled electric heating element which is mounted inside the heater housing to warm up the interior. When the PTC heater system is active there will be a lot less heat of the engine used to warm up the interior. The PTC heater system automatically shuts down if the engine temperature is above 80 degrees Celsius.
Where is it located and should i replace it or might there be another problem?
My A/C is also not working and my battery is bad (will replace asap), could it be related to either one of those?
2018 Ford TRANSIT Mk8 V363 Van (FCD, FDD) 2.0 EcoBlue RWD (125kW)
2018 Ford RANGER Limited 2.2 TDCi (118kW)
dannykater
Re: Error Code B153B PTC Heater circuit current above thresh
Postby metalworker0 » Thu Aug 29, 2024 7:53 pm
may not be that at fault .. from my search ...results not strait forward or confirming your diagnosis - this code is generic and usually followed by two digits more.
and think you mean DTC diagnostician-trouble-code not PTC
Postby dannykater » Fri Aug 30, 2024 10:04 am
I'll try and read the codes from Forscan tomorrow, see if i can get more out of it. Carly doesn't give the 2 digits folowcode unfortunately.
The "PTC Heater" is also called the "Electric Auxiliary Heater"
Cheers!
dannykater
Postby dannykater » Sun Sep 01, 2024 10:11 am
FORscan told me B153B:15-48 which was solved by putting my original drivers side mirror back.
Cheers
dannykater
