A/C and CruiseControl not working, but no codes in FOREscan
Postby dannykater » Fri Aug 30, 2024 9:05 pm
Hello!
My A/C and Cruise Control are not working, but i have no related error codes in FOREscan?
Is there a way to get a "deaper scan" into the A/C HVAC and Cruise Control?
Thanks!
2018 Ford TRANSIT Mk8 V363 Van (FCD, FDD) 2.0 EcoBlue RWD (125kW)
2018 Ford RANGER Limited 2.2 TDCi (118kW)
dannykater
Re: A/C and CruiseControl not working, but no codes in FOREs
Postby Altransit » Fri Aug 30, 2024 9:55 pm
I've had more than my fair share of A/C problems, and there are almost never any trouble codes to assist with diagnosis.
The most common problem is lack of gas.
Next, is a non-working or sticking engine fan, (or the smaller fan if you have two)
Thirdly, the compressor may have an unserviceable clutch
Postby dannykater » Sat Aug 31, 2024 12:04 am
Actually the clutch is completely gone haha Just figured that out today So i guess i'm replacing the compressor and hopefully all will be good!
I was just curious whether the only way to find the problem is by testing power circuits and visually checking parts haha So there's no deeper checks with software?
Thanks!
dannykater
Postby dumper » Sat Aug 31, 2024 7:44 am
My last job had a dedicated auto electrician and he always said that the coeds that gave a fault on some part of hardware wasn’t always that it was more likely to be wiring related before you change it he’d always check the circuit
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Altransit » Sat Aug 31, 2024 9:03 am
dannykater wrote:Actually the clutch is completely gone haha Just figured that out today So i guess i'm replacing the compressor and hopefully all will be good!
Thanks!
As Dumper said, it's always worth checking related fuses and wiring before you spend money. It's also worth powering up the fan remotely, because if that doesn't start to run, the aircon wont work.
Postby dannykater » Sat Aug 31, 2024 11:27 am
Alright, thanks for the tips!
In my case the clutch is missing, so i've got to replace the a/c compressor anyways right? I read that it's hard to find just the right clutch for the A/C compressor.
dannykater
Postby Altransit » Sat Aug 31, 2024 11:48 am
I had to buy a new compressor for mine when the clutch went, it cost over £500 with fitting!
I had bought a second hand unit which looked to be in good condition, but apparently, it didn't fit :roll:
Postby dannykater » Sat Aug 31, 2024 12:47 pm
Ah sh*t!
I just found just the clutch as well, for supposedly my specific A/C Compressor. Worth trying putting the clutch back on again first, i guess? See if the clutch gets engaged when turning on A/C?
If not, i'll replace the whole thing..
dannykater
