Which software to find part numbers for VIN
Postby dannykater » Fri Aug 30, 2024 9:09 pm
Hello,
Which software can be used best to find part numbers for my van based on the vin number?
I'm looking for a new A/C compressor, but on the parts websites there's so many different part numbers they link to my license plate and VIN, not sure which one is the right one!
Thank you!
2018 Ford TRANSIT Mk8 V363 Van (FCD, FDD) 2.0 EcoBlue RWD (125kW)
2018 Ford RANGER Limited 2.2 TDCi (118kW)
dannykater
Re: Which software to find part numbers for VIN
Postby Chug » Fri Aug 30, 2024 10:33 pm
Put your VIN into Catcar, at the top of the page here https://www.catcar.info/ford/?lang=en&l=
Chug
Postby dannykater » Sat Aug 31, 2024 12:02 am
I'm getting a "not found" error..
Can i post the VIN here? Or not recommended?
Thanks!
dannykater
Postby knobby1 » Sat Aug 31, 2024 3:39 am
dannykater wrote:I'm getting a "not found" error..
Thanks!
Try this:
https://www.catcar.info/ford/?lang=en&l ... U0ODgrMTM1
Postby dannykater » Sat Aug 31, 2024 11:28 am
Thanks!
Try this:
Thanks! Is the part number for the a/c compressor there the one i need? There's not different variants between different engines, FWD/RWD, years etc. etc.?
I did filter down in catcar to the right Engine, 350E Series and LHD RWD now!
dannykater
Postby dannykater » Sat Aug 31, 2024 12:29 pm
I just figured out the Engine Code as well: YNR6. It seems you can narrow down quite a lot based on this code!
It just shows me one option / part number for the A/C compressor now: GK3119D629CD. Thanks for help finding the part number!
Unfortunately there's only a few used ones available and new are 400-500 euros. Arghhh
dannykater
