Mk7 Euro4 FWD 5-speed to 6-speed gearbox conversion
Postby Cider Andy » Wed Sep 18, 2024 1:24 pm
Long time no post!
I have a couple of Mk7 FWD vans each with a 5-speed gearbox and may be looking to upgrade one or both to 6-speed. Obviously, I'll need a gearbox and gear lever assembly, but what else will I need?
Gear change cables?
Mountings?
Clutch?
Concentric slave cylinder?
Flywheel (both have a solid flywheel)?
Driveshafts?
Anything else?
Presumably it's been done before but I couldn't find anything relevant in the forum search for a FWD.
Cheers.
Andy.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Re: Mk7 Euro4 FWD 5-speed to 6-speed gearbox conversion
Postby andz327 » Wed Sep 18, 2024 1:39 pm
I wouldn't bother mate , not the best of gearboxes and you won't save any fuel almost certain final drive gear ratio is same between 5spd and 6sp, if your doing lot of motorway driving fit 16in wheels with a higher sidewall height that's what I done
andz327
Postby knobby1 » Wed Sep 18, 2024 8:22 pm
Cider Andy wrote:Long time no post!
Gear change cables?
Mountings?
Clutch?
Driveshafts?
Anything else?
Cheers.
Andy.
As our Andz said, waste of time...nothing to be gained by going to a 6 speed....the 5 speed box is more robust anyway.
Postby MinorMatt » Thu Sep 19, 2024 10:23 am
If you do decide to do it - I have a euro 4 FWD 6 speeder for spares/repairs I will be selling soon with good running gear (except a broken leaf) 16" wheels and all the toys... but its quite a long way from you
Postby Cider Andy » Thu Sep 19, 2024 1:34 pm
andz327 wrote:I wouldn't bother mate , not the best of gearboxes and you won't save any fuel almost certain final drive gear ratio is same between 5spd and 6sp, if your doing lot of motorway driving fit 16in wheels with a higher sidewall height that's what I done
knobby1 wrote:As our Andz said, waste of time...nothing to be gained by going to a 6 speed....the 5 speed box is more robust anyway.
Cheers gents.
Hmm, I thought 6th gear was quite a bit taller on the FWD (I know they're about the same, or even worse, on the RWD)? But I didn't know the 6-speed was more fragile.
Cider Andy
Postby Cider Andy » Thu Sep 19, 2024 1:35 pm
MinorMatt wrote:If you do decide to do it - I have a euro 4 FWD 6 speeder for spares/repairs I will be selling soon with good running gear (except a broken leaf) 16" wheels and all the toys... but its quite a long way from you
Cheers Matt. Good stuff's worth travelling for...
Cider Andy
Postby andz327 » Fri Sep 20, 2024 9:26 pm
MM what's up with the one your selling apart from spring ??
andz327
Postby MinorMatt » Sat Sep 21, 2024 9:54 pm
Theres a list... but mostly rust
Postby andz327 » Sat Sep 21, 2024 11:22 pm
How bads the rust and much shekels you looking for it
andz327
Postby MinorMatt » Mon Sep 30, 2024 1:26 pm
Sorry Andz - didn't see this until now
