Prop shaft bearing.
Prop shaft bearing.
Postby Harvy » Sun Oct 06, 2024 3:14 pm
I’ve been having a look under my Newley purchased van today and come across a prop shaft bearing that has completely gone. They don’t look too complex to replace. I can’t seem to find the part on fords website, is there somewhere else I should be looking for genuine parts? I’ve found a pair of centre bearing on eBay for only £30. Would these be alright?
https://www.ebay.co.uk/itm/154009631108 ... p_homepage
Is there a good place to buy new transit parts? I’ve never had a van before so just used Gsf or Eurocarparts when I needed non genuine parts.
Thanks in advance.
2010 T350 LWB H3 RWD 2.4 115 Full poverty spec! :D
Harvy
Re: Prop shaft bearing.
Postby Airthies » Sun Oct 06, 2024 3:33 pm
Depending on the van and spec, there are two diameters of center bearings 30mm and 35mm
If you have calipers big enough you can measure the prop tube to hopefully give a better idea of which one you have before dismantling.
What I've found is (But don't quote me on this)....
Tube diameter
80mm = 30mm bearing
85mm = 35mm bearing
There's cheap and then there's cheap.
I just go to my local independent motor factors and get a decent branded version.
It's good to nurture a decent relationship with a local factors, as, if you find something that doesn't fit you can walk in and discuss the options and you can work out between you the exact part you want/need.
Be aware the splines can be very tight to come apart on some propshafts and mark the each joint to make sure it gets back on the correct orientation.
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Harvy » Sun Oct 06, 2024 4:30 pm
Thanks for the advice. I had meant to put a signature in describing my van before I posted, I’ve done it now. I will give my local spares place a call tomorrow and see if they can get parts. My gearbox is a 6speed so it would appear to need the 35mm bearings.
Harvy
Postby Airthies » Sun Oct 06, 2024 5:25 pm
Harvy wrote:Thanks for the advice. I had meant to put a signature in describing my van before I posted, I’ve done it now. I will give my local spares place a call tomorrow and see if they can get parts. My gearbox is a 6speed so it would appear to need the 35mm bearings.
I've had both sizes on what appears on paper to be identical vans.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby Harvy » Tue Oct 08, 2024 7:55 am
I got a 31mm bearing from my local motorfactors and it fits fine!? The chap there was convinced it was the only one that would fit my van. I’ve ordered a second one to replace the second bearing. I didn’t take my callipers with me so couldn’t accurately measure the shaft itself. I’ll try to remember next time.
Harvy
