GLOW PLUG SENSOR CIRCUIT
Postby leestransit » Sun Oct 13, 2024 6:03 pm
hi everyone i am after some advice
i currently have a 2013 ford transit mk7
ex british gas van
P0671:00-2f cylinder 1 glow plug open circuit
P0671:00-2f cylinder 2 glow plug open circuit
P0671:00-2f cylinder 3 glow plug open circuit
P0671:00-2f cylinder 4 glow plug open circuit
P037D:00-2F glow plug sense circuit
any ideas where to start with this reading from the scanner ?
surely not all the glow plugs fail at he same time
any info would be greatly appreciated
thanks
leestransit
Re: GLOW PLUG SENSOR CIRCUIT
Postby metalworker0 » Sun Oct 13, 2024 6:36 pm
Think there is a weak link ..if any of the glow plugs fail, in the way of going to ground, this link burns through, think you are supposed to buy the whole wire that links all of them ..but people have soldered a 60 amp fuse in place. where the break is.
The only reference i can find on ebay for a new wire is to use the word "wire" ..not loom.
so your search is:
transit mk7 glowplug wire
There are two brand new glow plug wires on there that are genuine ford, just over £60 ..both have different part numbers ..that's something you are going to have to figure out yourself.
Then test each glow plug before you fit it , to see which one needs replacing ..i hear that it does not actually need the glow plugs to start ..and they are there to stop it smoking on start up, and make it run smoother on start up. that's unless its minus conditions then they will be needed.
Postby leestransit » Mon Oct 14, 2024 8:16 am
oh that is a great help
ill give ford a ring see what they say
many thanks
leestransit
Postby metalworker0 » Mon Oct 14, 2024 8:04 pm
do the checks first before ordering anything.
Postby metalworker0 » Mon Oct 14, 2024 9:07 pm
well it turns out the chap i answered to above has a different glowplug wiring loom then what i answered for ..his has 4 wires
seems there are two types 4 wire and single wire
can anyone give him tips on testing and diagnosing the 4 wire one ..
Postby leestransit » Tue Oct 15, 2024 7:30 am
TRANSIT MK7 2013
i located the big aluminiUm relay behind the headlamp and followed the wires from the relay down to the top of the engine where it connects to the loom part
Glow Plug Control Unit fits FORD TRANSIT 2.2D 2007 on ECU Hella 1719477
i put a bulb type tester on each of the 4 wires
3 of the wires did show the bulb lite up
the last one did not light up
if the power to that connection is coming from the relay
should all 4 light up if the relay is working correctly ?
i think the one which did not light up was like a yellow wire with a blue line on it the end one
it would be so much easier to swap the relay :D :D
many thanks
leestransit
Postby dieseltrucking » Wed Oct 16, 2024 1:56 am
The issue is likely not with the glow plugs themselves but with the glow plug control module/relay, wiring, or fuses. Start by checking the control module/relay, inspect the wiring for damage, test the glow plugs' resistance with a multimeter, and check the fuses. The P037D code may also indicate an issue with the feedback circuit. Focus on common points affecting all plugs, like the control module and wiring.
dieseltrucking
Postby leestransit » Sun Oct 20, 2024 10:16 pm
well here is the update to my original question
after taking out the glow plugs to investigate the error codes
3 glow plugs when tested were dead
1 glow plug when tested absolutely popped like a firework
so i replaced all 4 glow plugs
i also got a new loom from ford which was £60
and a brand new glow plug relay £60
fitted it all turned the key and started like a dream
checked with the scanner and all was good
took the van for a 10 mile drive 4th gear at 55mph to try and see if it would do a regen
no smoke no rattles
got back re scanned it - all good
leestransit
Postby metalworker0 » Sun Oct 20, 2024 10:37 pm
That's great news - thanks for the update :D
All the best.mark
Postby Y-van » Wed Nov 27, 2024 5:55 pm
I'm curious what the labour for the glow plug replacement cost you.
Mine is in the shop today to have all 5 replaced.
Donut Delivery Fleet:
2010 Econoline E-150 Gas 153000km
2017 Transit T-250 Diesel 253000km
2019 Transit T-250 Gas 233000km
Y-van
