2.5di 1985 crankshaft pulley bolt
Postby Rockinronnie66 » Fri Oct 25, 2024 7:35 pm
Hi all Im trying to do the cambelt on a 1985 2.5di but!
I can’t get the crank pulley off I’ve tried everything scaffold bar on a 3/4” 36mm socke it won’t budge!
Any suggestions??!! :o
Rock”n”Roll Baby!
Rockinronnie66
Re: 2.5di 1985 crankshaft pulley bolt
Postby metalworker0 » Fri Oct 25, 2024 8:15 pm
Perhaps someones put it in with red loctite ,..if so, the bolt will have to be heated up, to about 250c to melt the loctite. I've no idea if you are going to damage the crankshaft oil seal, or the pulley torsional rubber damper if you do this.
Or you are buying or lending a hefty air gun or battery powered impact wrench.
Postby Rockinronnie66 » Fri Oct 25, 2024 9:43 pm
That’s a thought yes maybe they have I have heated it up sum.
Ive got another oil seal but I am concerned about the rubber damper.
I have been lent a tourque multiplier gonna give it a try.
Thanks for that.
Rock”n”Roll Baby!
Rockinronnie66
Postby Keef » Fri Oct 25, 2024 10:34 pm
Why are you taking the crank pulley off?
There's no need is there?
viewtopic.php?f=18&t=56801
Keef
Postby Rockinronnie66 » Sat Oct 26, 2024 4:30 pm
Did it heated bolt while cooling down pulley with water 3/4 bar pole, ow and 13 stone on the bar!
Yippee just gotta tourque it up now!
Rock”n”Roll Baby!
Rockinronnie66
Postby Rockinronnie66 » Sat Oct 26, 2024 4:33 pm
You have too take it off to change crank oil seal and timing belt.
Rock”n”Roll Baby!
Rockinronnie66
Postby metalworker0 » Sat Oct 26, 2024 4:37 pm
well it needs a new crank pulley ..as the rubber is cracked, it last a few months though
Postby Rockinronnie66 » Sat Oct 26, 2024 4:39 pm
Oooow get you.
Rock”n”Roll Baby!
Rockinronnie66
Postby Rockinronnie66 » Sat Oct 26, 2024 4:40 pm
Tried to find one guess it’s gonna stay cracked…
Rock”n”Roll Baby!
Rockinronnie66
Postby metalworker0 » Sat Oct 26, 2024 4:41 pm
like i said crack not all the way around ..will last a few months ..keep an eye on it
Postby V184 » Sat Oct 26, 2024 10:04 pm
Rockinronnie66 wrote:You have too take it off to change crank oil seal and timing belt.
Pulley bolt socket size 36mm :wink:
V184
Postby MinorMatt » Wed Oct 30, 2024 10:48 am
To change the seal - yes
to change the belt the pulley stays on.
