Mk7 2.4 won’t start off the key
Postby Js mortar » Sun Oct 27, 2024 2:26 am
Hi all stuck with the truck it turns over and over it’s trying to start but won’t a little east start squirted in and boom she fires up and runs and bricks over sweet as a but no codes but if you give it pedal to the metal o Gordon limp mode cog lights comes on flick the key on and off and then it’s back to ok
Just stuck on starting off key 2 new battery’s on voltage on live data iOS good checks all fuses been over everything twice anybody have any idea ms I’ve ran out
Js mortar
Re: Mk7 2.4 won’t start off the key
Postby andz327 » Sun Oct 27, 2024 4:17 am
Did you have any work carried out just before this started happening??
andz327
Postby Js mortar » Sun Oct 27, 2024 5:07 am
No nothing it’s got me baffled
Js mortar
Postby Airthies » Sun Oct 27, 2024 8:37 am
What codes you seeing since it's going into limp mode?
Is it spinning fast enough to start? It may be a lazy starter motor despite having two new batteries.
Are the batteries correct CCA ?
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
