1997 Heater Blower failed
Postby Nic1234 » Wed Oct 30, 2024 1:02 pm
Hello, I recently purchase this van and discover that when I turn the ignition key the 30amp fuse immediately blows with a significant flash, even when the Fan speed control switch is off. Any advice would be greatly appreciated.
Nic1234
Re: 1997 Heater Blower failed
Postby knobby1 » Wed Oct 30, 2024 11:35 pm
Nic1234 wrote:Hello, I recently purchase this van and discover that when I turn the ignition key the 30amp fuse immediately blows with a significant flash, even when the Fan speed control switch is off. Any advice would be greatly appreciated.
If the fuse is blowing straight away, you must have a dead short somewhere in the blower/wiring.
Postby bortaf » Fri Nov 01, 2024 1:27 am
unplug the heater motor and try again, sometimes the heater motor overheats and melts internaly shorting it out and or the heater switch can melt if the motor is rum on full for long periods of time :?:
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby Nic1234 » Mon Nov 04, 2024 1:58 pm
Thanks Gents, I’ve disconnected the Blower and Speed Control Switch and the fuse still blows when ignition switch turn on. Is there a way for me, a below average tinkerer, to test where the fault is or are you able to point me towards an auto electrician?
Nic1234
