MK6: Odd squeaking noise when turning engine off?
Postby cam.on.wheels » Sun Dec 01, 2024 8:04 pm
Hi guys
My 2010 MK6 makes this squeaking noise when turning off the engine.
https://we.tl/t-AcFn48YEHf
Any idea what could be the problem - and if it's possible to fix it without having to take it to the mechanic?
Appreciate any help
- Cam
cam.on.wheels
Re: MK6: Odd squeaking noise when turning engine off?
Postby metalworker0 » Sun Dec 01, 2024 8:48 pm
You have no chance of me pressing agree ..and no other choice, on that site you directed us to
so please put it on youtube
Postby cam.on.wheels » Sun Dec 01, 2024 9:05 pm
Hi Mark
Thanks for the tip, posted it on YouTube instead:
https://youtube.com/shorts/aG0boH89oog?feature=share
- Cam
cam.on.wheels
Postby Chug » Sun Dec 01, 2024 9:22 pm
If it sounds like a hacksaw then its probably the EGR doing its self cleaning cycle
Chug
Postby cam.on.wheels » Sun Dec 01, 2024 9:44 pm
I think that might actually be it
Just googled a bit and it seems that others are experiencing the same thing
There doesn’t seem to be a solution to get rid of the sound though..
Anyways, thanks for solving the mystery!
- Cam
cam.on.wheels
Postby metalworker0 » Sun Dec 01, 2024 11:19 pm
Sounds like to me the engines rocking on its worn mountings when you turn it off ...only confirmed by someone else turning it off and you looking at the engine to see what is happening.
other causes --
1. if rear wheel drive ---cooling fan clutch worn. or touching shroud at turn off.
2. if AC left on when stopped --- its the clutch on the compressor malfunctioning.
3. Aux belt too tight.
Postby knobby1 » Tue Dec 03, 2024 5:32 am
cam.on.wheels wrote:I think that might actually be it
- Cam
If it is the EGR doing its "self clean" it's normal..
Check the crank pulley rubber, they fall apart with monotonous regularity.
Postby DanMK7uk » Tue Dec 03, 2024 9:01 pm
Lord Knobrot[/quote]
Do the mk7 euro 4s suffer with them too ? Mines just that. Be good to know if something to keep an eye on..
Cheers
DanMK7uk
Postby MinorMatt » Wed Dec 04, 2024 3:49 pm
DanMK7uk wrote:Check the crank pulley rubber, they fall apart with monotonous regularity.
Cheers[/quote]
Yes - they are worse.
Postby knobby1 » Wed Dec 04, 2024 8:06 pm
DanMK7uk wrote:Do the mk7 euro 4s suffer with them too ? Mines just that. Be good to know if something to keep an eye on..
Cheers
As our MinorMatt said....they are often worse, the Mk6 Euro-3 has a much better crank pulley....they are interchangeable on the 2.4's too.
Mine fell apart in my driveway one morning as I was on my way to work....I fitted a cheap ebay pulley and it has been there ever since...has lasted longer than the original Ford item.
Postby DanMK7uk » Wed Dec 04, 2024 8:18 pm
Good to know LK. Is there anything you dont know about transits ! Incredible knowledge
https://www.amazon.co.uk/Double-Cranksh ... d_source=1
This is the type i have on mine , maybe not original but it dont have the big rubber section just a thin maybe 10mm width of rubber. Are these more reliable than the ones with the wide section damper ?
DanMK7uk
Postby knobby1 » Thu Dec 05, 2024 12:36 am
DanMK7uk wrote:Good to know LK. Is there anything you dont know about transits ! Incredible knowledge
LOL...there's chaps on here who have "much" more Transit knowledge than myself. I know lots of useless crap, ask my missus. :mrgreen:
The pulley you've linked to is for a Mk7 FWD....the OP has a Mk6 RWD, they only have the one serpentine belt.
