Ford Tourneo custom 2013 won't start
Postby Robbie 76 » Tue Dec 03, 2024 4:54 pm
Help please Ford Tourneo custom 2013 model 2.2 litre diesel
Took car for service few weeks ago
Drove 3 miles home OK now turns over but won't start.
Checked underneath near fuel filter and the Slimline black plastic pipe from the high pressure pump to the rear of the engine was broken and hanging down.obtained new pipe and connected all again but looks as though no fuel is coming out of the pipe now. so no feed to the injectors.
Fuel reaching the filter ok from the electric pump in the tank
I also have a engine malfunction message with red light on dash
Does anyone know if and when the high pressure fuel line is interrupted if there is a reset process for safety reasons Also any other ideas to get me going again
Any advice would be much appreciated
Thank you Robbie
Robbie 76
Re: Ford Tourneo custom 2013 won't start
Postby Robbie 76 » Tue Dec 03, 2024 5:09 pm
Hi again sorry I forgot to ask is there any that I can briefly bypass the high pressure fuel pump delivery except for easystart just to help eliminate anything not related to the pump itself Thank you again Robbie
Robbie 76
Postby andz327 » Tue Dec 03, 2024 5:41 pm
Robbie 76 wrote:Hi again sorry I forgot to ask is there any that I can briefly bypass the high pressure fuel pump delivery except for easystart just to help eliminate anything not related to the pump itself Thank you again Robbie
No the van needs to see the high pressure or it won't start
andz327
Postby knobby1 » Tue Dec 03, 2024 8:06 pm
Robbie 76 wrote:I also have a engine malfunction message with red light on dash
Thank you Robbie
What fault codes are you getting..?? This may help point you in the right direction....
And as our Andz said, no high pressure pump = no start. The high pressure pumps very rarely fail.
