2018 Transit injector failures
Postby Daitch » Sun Dec 08, 2024 3:30 pm
My 2.0L eco diesel transit based motor home ( manufactured Sept 2018 ) has travelled only 8.5K miles and
So far has had 9 injectors fitted ( including the originals). The last replacement was a week ago. Can I expect more trouble or are the newer injectors more reliable ?
Daitch
Re: 2018 Transit injector failures
Postby knobby1 » Sun Dec 08, 2024 8:43 pm
Daitch wrote:My 2.0L eco diesel transit based motor home ( manufactured Sept 2018 ) has travelled only 8.5K miles and
Just my humble opinion....but ......Unfortunately the 2.0L Eco engines are well known to be junk....injectors fail constantly....they throw wet belts with monotonous regularity and clog up the oilways with the bits of wet belt floating around inside the engine, this is well documented and unfortunately very common. I understand there may be some civil law suits as a result.
Postby Daitch » Wed Dec 18, 2024 6:40 pm
Thanks , it sounds bad - just as I’d feared.
I might stick to uk holidays ☔️
Daitch
Daitch
