2004 mk6 2.4td Fuel pipe layout
Postby JRHartley » Wed Dec 18, 2024 6:26 pm
Does anyone know of a pic' showing the pipe layout from the fuel tank to the filter head?
I'm going to add a lift pump is there any easy way to determine the flow & return pipes ? thank you
JRHartley
Re: 2004 mk6 2.4td Fuel pipe layout
Postby knobby1 » Wed Dec 18, 2024 8:38 pm
JRHartley wrote:Does anyone know of a pic' showing the pipe layout from the fuel tank to the filter head?
Is there a reason you're going to fit a lift pump..?? Not really required if the system isn't leaking air in.
The early 120/125 TDDi's had a lift pump on the filter housing....but they deleted it soon after I believe.
https://www.catcar.info/ford/?lang=en&l ... NzkyKzA%3D
Fuel lines from tank to filter head:
https://www.catcar.info/ford/?lang=en&l ... IrMA%3D%3D
Postby JRHartley » Wed Dec 18, 2024 9:58 pm
That's very helpful thanks, its a 90hp model so no lift pump. Looking at vids on the net it looks difficult to bleed the fillter etc. So I want to fit a pump.
Do those filter condition indicators work well?
JRHartley
Postby JRHartley » Wed Dec 18, 2024 10:33 pm
Does the pump return the diesel to the fuel tank via the filter housing ? Is that to help it bleed the system?
JRHartley
Postby knobby1 » Thu Dec 19, 2024 12:18 am
JRHartley wrote:That's very helpful thanks, its a 90hp model so no lift pump. Looking at vids on the net it looks difficult to bleed the fillter etc. So I want to fit a pump.
The yellow filter "clogging" indicators do indeed work ok.
Far to many people think they're a primer button for some strange reason.
Postby knobby1 » Thu Dec 19, 2024 12:23 am
JRHartley wrote:Does the pump return the diesel to the fuel tank via the filter housing ? Is that to help it bleed the system?
The fuel return "from" the the pump returns via the filter head, I believe it's just a "pass through", then goes to the fuel cooler, (if fitted), under the van and then to tank.
