Blower motor on 2024 Ford Transit 250 Van not working
Postby Mykra » Fri Feb 07, 2025 2:25 am
Hey all first time here.
I have a 2024 Ford transit 250 Extended Van here with a blower motor that is not working.I put it on the scanner which shows: b10b9:14-0A Blower Control.
I checked the voltage on both the blower motor (under the glove box) and blower module (behind the glove box) connections and it’s 0. The nice thing is that I have another exact Transit here with a working blower and checked the voltage on it and it’s reading 12V.
The manual is not clear on which fuses or relays are for the blower (sorry if i missed it complete newbie here) but i did check the 7.5V climate control fuse and it’s ok.
Not sure what my next steps should be here…any guidance is greatly appreciated.
Mykra
Re: Blower motor on 2024 Ford Transit 250 Van not working
Postby metalworker0 » Fri Feb 07, 2025 3:09 pm
if you are in the united states ..i sourced this thread with every bit of info you ever are going to need
Yes, i know it a ford ranger ., but thee is every chance that this thread serves its purpose of diagnosing your fault as its probably very similar of the same .. and some clever very knowledgeable guys on the thread ..
https://www.ranger5g.com/forum/threads/ ... ing.26174/
Postby Mykra » Fri Feb 07, 2025 3:16 pm
Thanks Mark!
Mykra
Postby metalworker0 » Fri Feb 07, 2025 8:06 pm
Since it is a 2024 model - Think the fellow on the transit USA forum who said take it in for warranty work, has the best answer.
